Message 1 of 28
faults
how do i get any sense out of the fault service, i have spent nearly two days reporting a fault on my broadband speed, dealing with india on the phone and the chatline, i have had engineer appointments made and cancelled no end opf promises, and my broadband still runs at 26mb and not the 54mb i am paying for. i am at my wits end, can anybody help me please
27 REPLIES 27
Message 2 of 28
Re: faults
is your phone line noisy?  dial 17070 option 2  should be silent and best with corded phone
can you post stats from your hub  if hh6 then advanced settings then technical log information
enter phone number and post results  remember delete number    https://www.dslchecker.bt.com/adsl/adslchecker.welcome
Message 3 of 28
Re: faults
sorry too technical for me
Message 4 of 28
Re: faults
the phone check is quite simple to see if line ok  just dial 17070 option 2
Message 5 of 28
Re: faults
i still need some help please
Message 6 of 28
Re: faults
hi thank you,the quiet line test was ok, sorry to be a pain im new to all this
Message 7 of 28
Re: faults
do you notice if the light on the hub changes colour from normal blue?  do you notice if your internet conenction stops working? often?
enter 192.168.1.254 into your browser address bar and then enter admin password form hub then go to advanced settings then technical log information and can you post the hub stats you see
Message 8 of 28
Re: faults
have the info required how do i send it to you, hub colour changes occasionally.
Message 9 of 28
Re: faults
to post the stats  use the camera shown here
Message 10 of 28
Re: faults
