mshaw43488
Message 1 of 7
fec events
good eve, can someone clarify if i should be concerned about the high number of FEC events here, or does everything look ok
thanks
ADSL Line Status
Connection Information
Line state:Connectedppp0_0
Connection time:0 days, 04:21:48
Downstream:9.364 Mbps
Upstream:1.095 Mbps
ADSL Settings
VPI/VCI:0/38
Type:PPPoA
Modulation:G.992.5 Annex A
Latency type:Interleaved
Noise margin (Down/Up):4.7 dB / 6.1 dB
Line attenuation (Down/Up):37.4 dB / 22.6 dB
Output power (Down/Up):20.2 dBm / 12.7 dBm
FEC Events (Down/Up):167809 / 270
CRC Events (Down/Up):396 / 50
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
HEC Events (Down/Up):6957 / 48
Error Seconds (Local/Remote):177 / 32
6 REPLIES 6
Message 2 of 7
Re: fec events
there is nothing to worry about FEC's just show that interleaving is working
conrad
Recognised Expert
Message 3 of 7
Re: fec events
FEC essentially show that interleaving is working and you can have high values without it causing problems.
I personally would just keep an eye on your errors as they are on the high side for just a 4 hour connection - it may be due to the time of day. just keep a record of them at the same time each day to see if the increase is consistent.
So long as your throughput is not reduced then things should be ok.
mshaw43488
Message 4 of 7
Re: fec events
grreat thanks for your help , what about the other events such as crc and hec are those also ok?..do you think i have a reasonable connection for my line length?
Message 5 of 7
Re: fec events
Your connection looks ok and errors should not cause you a problem. Your noise margin is already below 6db so cannot see any scope for faster. According to kitz maybe about 10mb
Are you connected using the test socket?
mshaw43488
Message 6 of 7
Re: fec events
yes plugged into the master socket, no noticable noise on the line either.. so that must be all iam going  to  get
Message 7 of 7
Re: fec events
Sorry do you mean the master or the socket behind the detachable bottom half - the test socket. The test socket eliminates any problems caused by your internal wiring and should be your best connection
