Message 1 of 4
i have just found out that i can get fftp , its says stage one and i am able to order a ont box.
but when i looked in the community the ont box 250 mm x 200mm looks to big to have in a living room .
do i have to pay for the ont box to be installed.
at the moment i am on fftc getting 8mbs download and 1mbs upload.
also i will have to find out what packages bt are offering for fftp.
3 REPLIES 3
Message 2 of 4
Re: fftp
I think you mean FTTP.
The ONT will be fitted as part of the install and is usually located on the inside of an external wall where the fibre enters. Similar to your existing master socket.
Message 3 of 4
Re: fftp
Sorry about the mistake,  i did mean fttp.
Just went on my bt to see what deal i could get. Full fibre  £73.99 ☹
Message 4 of 4
Re: fftp
Give 0800 800 030 a call and see what you can negotiate.
