Message 1 of 14
fibre broadband
Hi
Looking for some help here as hitting a brick wall for last 6 months
I have got broadband *Edited By Mod* For last 6 months trying to upgrade it for fibre one but no luck so far. Checked Openreach for my area and they accepting orders for super fast fibre. Contacted *Edited By Mod* through email ( many of times) but as a result every time in 3-5 days getting the reply it's not available. What shall I do now?? Help.... very frustrating
Thank you
13 REPLIES 13
Message 2 of 14
Re: fibre broadband
Enter your phone number HERE and post a screenshot of the result. Remove number before postion.
Message 3 of 14
Re: fibre broadband
are you currently a BT broadband customer?
Message 4 of 14
Re: fibre broadband
Tags (1)
Message 5 of 14
Re: fibre broadband
Sorry..I will sound silly now...How to copy the screenshot in this forum ☺
Tags (1)
Message 6 of 14
Re: fibre broadband
Tags (1)
Message 7 of 14
Re: fibre broadband
Here is how to post pictures.
 https://community.bt.com/t5/help/faqpage/faq-category-id/images#images
Message 8 of 14
Re: fibre broadband
Message 9 of 14
Re: fibre broadband
That would appear to confirm it is available to you.
I see no reason why the dept you are dealing with are saying it isn't unless the cabinet was full and more capacity has now been added.
Don't forget this is a customer - customer support forum.
Message 10 of 14
Re: fibre broadband
Try phoning options team on 0800800030 they are uk based
