GP555
Message 1 of 10
fibre cabinet ready to order
Hi
My cabinet got enabled 30th September and only today is it avaiable to order, although i am going to order the speeds do seem a bit low at 27mb down and 5mb up, I live on  a new build estate, the street opposite where the show home takes a line from a overhead cable can get 62mb down, and upload speed of 20mb according to the checker.
Will the fibre speed be so different for just one street apart?
Gray
9 REPLIES 9
Guru
Message 2 of 10
Re: fibre cabinet ready to order
How are you getting the estimate, post code or phone number?
Use your post code it will provide the most accurate estimates.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
GP555
Message 3 of 10
HI
I Used my phone number, BT infinity and plusnet show the same 27mb speed to order, putting in the postcode shows no fibre available.
Hopefully this will increase with time.
Guru
Guru
Message 4 of 10
Hi GP555,
The speed will vary depending on how far away you live from your FTTC cabinet. The further away you live from the cabinet the lower your estimation will be.
Hope that helps,
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Guru
Message 5 of 10
You want to use your phone line, it's the most accurate if it shows up when you enter your phone number you can order.
GP555
Message 6 of 10
Hi
Just went to order fibre tonight and the BT checker and plusnet checker show no fibre is available to order, only normal ADSL !!
Strange as I was on the book an engineer date time page on plusnet's site but did not know the exact date I would be at home so I left it until today.
Hope this is a glitch with the checker!
Gray
GP555
Message 7 of 10
Hi
Gray
Distinguished Expert
Message 8 of 10
if you order plusnet your in the wrong forum
GP555
Message 9 of 10
Checker problem
Hi
Gray
Message 10 of 10
Re: Checker problem
lol
