Message 1 of 9
fibre speed between exchange and cabinet
8 REPLIES 8
Message 2 of 9
Re: fibre speed between exchange and cabinet
Does anyone know what speed (up and down) the speed of the fibre link between the exchange and the FTTC is?
Message 3 of 9
Should be about a max 80Mb DL and 20Mb UL I think.
If you're doing a speed test make sure to do it via the LAN cable not wirelessly.
Guru
Message 4 of 9
the speeds curiousfollow quotes is cabinet to modem.
I seem to remember reading that exchange to cabinet link would cope with about 80 full speed connections, so around 80x80Mbps=6,400 Mbps.
I can't find my source for that though and my memory isn't marvellous: someone will almost certainly come in and correct me ....
Message 5 of 9
Blimey! Only 80 full speed connections, that doesnt seem a lot before degradation starts.
How many connections does a cabinet normally have before being classed as full or needing an upgrade?
Message 6 of 9
most cabinets can take 128 connections
Guru
Message 7 of 9
The amount of connections available in the cabinet depends on the type and there is enough bandwidth for a theortical maximum of 80/20 on each line back to the exchange.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Message 8 of 9
I'm asking about the fibre speed from the exchange to the Fibre Cabinet not the bit between the Cabinet and the property!
- I would have though that the speed would be around several hundred Mbps enough to serve a fully connected Fibre Cabinet.
Recognised Expert
Message 9 of 9
The cabs are uncontested at the moment iirc. Each card in the cab has its own fibre back to the exchange, again iirc.
