Message 1 of 7
forgot wireless key and wireless password
ive forgot my wireless password and key and cant work out how to sort it out any ideas?
6 REPLIES 6
deltaflyer
Message 2 of 7
Re: forgot wireless key and wireless password
just log in to your hub via ethernet & all the details will be there
free your computer, use opensource
i'm a linux user & very happy about it
Distinguished Guru
Message 3 of 7
As the last poster has said, connect via an Ethernet cable, go to the hub home page and look for the wireless settings.
allanm
Message 4 of 7
If you cannot access HUB with Ethernet cable, you could factory reset your HUB and use the defaults printed on
back of HUB. But would try and get hold of Etehrnet cable and try that first
Allan
Rottie
Expert
Message 5 of 7
Hi there,
If you haven't changed the wireless password, etc from the defaults, then look on the back of the HomeHub and the defaults are there. 🙂
I don't know if this solution works for HomeHubs prior to v2.b as this is the model I have.
Hope this helps. 🙂
Message 6 of 7
i forgot my wireless password
Message 7 of 7
Log into your hub... It's there under "wireless Key"
An MSCE in computing is like having a McDonalds Certification in World Cuisine, pointless.
