BrandonS
Newbie
Message 1 of 6
getting terrible upload speed
i was told by many people that bt infinity had the best upload speed for uk and well..
http://www.speedtest.net/result/1912964789.png doesnt look good to me.
what can i do to make it faster?
5 REPLIES 5
Message 2 of 6
Re: getting terrible upload speed
Those speed tests look very wierd for Infinity. Can you run the BT Speedtester using the ADSL /FTTC option and post the IP profiles you get. Also were you using a wireless link while testing?
BrandonS
Newbie
Message 3 of 6
uhh how do i get the tester thing? and im using the yellow wire connecting from the hub to my pc.
Message 4 of 6
speedtester.bt.com is what you need
BrandonS
Newbie
Message 5 of 6
ok so i did the bt speedtester thing and here it is http://i44.tinypic.com/5x4g89.png
Message 6 of 6
Do you have FTTC or ADSL?
