I've had a very busy month this month and needed to send a lot of data, I figured I'd check my usage and it says "382.31 GB" used. As far as I am aware there is a 300GB cap, what happens after that is anyones idea. My speed doesn't appear to have been reduced
This speedtest was taken at 8:30pm Wednesday evening (peak time)
[URL=http://www.speedtest.net][IMG]http://www.speedtest.net/result/1557090276.png[/IMG][/URL]
What happens once one goes over the limit? I haven't been assasinated by ninja's, the sky hasn't turned red and my internet still works perfectly and solidly?
Solved! Go to Solution.
What broadband package are you on 10Gb, or Unlimited.
There is not a 300Gb package.
You might be getting mixed up with the old 300Gb limit which was done away with months ago.
So if you are on the unlimited package , there is no cap
[edit[ beaten to the punch
Yeh I am on "unlimited" and really? they did away with the 300gb limit? that's really good. I've spent this month trying to curbe my usage incase it went to far over. also virgin still have a limit i'm surprised BT have taken the higher ground on this one, in the past they've been pretty tight with limits
And following up at the rear....
See KerryG BT Community Manager's message #18 in this thread.-
http://community.bt.com/t5/BB-Speed-Connection-Issues/BT-TO-SCRAP-300GB-LIMIT/m-p/141429
PC (NDEGR)
My first month, and there are plenty of people who do a lot more
