iamjezz
Message 1 of 4
google on hub config - home hub
Hi ive purchased a google onhub for IFTT intergration, i basically want to turn my home hub 4 into a modem.
i have conected the 2 via ethernet and my wifi works, however i want to dissable DHCP on the homehub so i can utilise the onhub more.
When i do this i get a sign in request when using wifi.
these are some of the options i have ( limited for a fancy router i know)
will i need to type in information with regards to the pppoe, all i can find on the bt router is bthomehub@btbroadband.com with a password that is stared out.
also my bt homehub has the address of 192.168.1.254
Screenshot_2016-09-21-12-34-00.pngScreenshot_2016-09-21-12-47-41.pngScreenshot_2016-09-21-12-47-48.pngScreenshot_2016-09-21-12-47-51.png
3 REPLIES 3
Ectophile
Distinguished Guru
Message 2 of 4
Re: google on hub config - home hub
Home Hubs don't have a modem mode.  All the home router functionality is turned on permamently.
iamjezz
Message 3 of 4
assuming your turn off dhcp-wifi your basically left with a modem?
licquorice
Message 4 of 4
Not really, modem like functionality, but not true modem. The PPP layer, routing and NAT will still be dealt with by the hub.
