Message 71 of 76
Re: have achieved double speeds and back to slow mode again
hi this link should explain in more detail http://kitz.co.uk/adsl/linestats_errors.htm rs errors are basically showing that interleaving is on and working
Message 72 of 76
well ive not got a constant snr of
Noise Margin8.6 dB
give or take a .2, usually on the old router it bounces about all over and then causes constant restarts. do you think it is now worth asking for a (Final) snr reset once again ?? as i do beleave the problem is cured. 🙂
Message 73 of 76
you can certainly ask for a reset contact the mods
Message 74 of 76
well i will ask, its defo worth it now the problem has been finally solved after all this time !!
i think i mite be getting really on the t.i.t.s now though contacting them all the time haha., but hey
if they can do it ten times, they can do it 11 right ?? lol
Tags (1)
Message 75 of 76
well have sent the mods an email 🙂 hopefully with a bit of luck it will all be sorted out some time this morning 🙂
Message 76 of 76
hi remember it can take up to 72 hours for them to get back to you
