Message 1 of 10
here we go again...
OK so a while back I posted a question about the terrible upstream speed I get where I live, which Download was 15 ish and upload use dto sit around 0.8
So now, download is 10 and up is 0.4
Since Ive lost 5 mbps down a new fibre cabinet has appeared and im really struggling to get an answer or any further forward with BT or openreach to at least restore my previous speeds.
Attached is my router dsl stats and a pic of the dsl checker info.  Does anyone know if it is right with what my router is syncing at ?
Version:1.0 StartHTML:000000225 EndHTML:000014214 StartFragment:000007571 EndFragment:000014108 StartSelection:000007768 EndSelection:000014066 SourceURL:http://192.168.1.1/Main_AdslStatus_Content.htm?t=1522267941456 ASUS DSL-AC88U Dual-Band Wireless-AC3100 Gigabit VDSL2/ADSL2 Modem Router - DSL Log
DSL Driver VersionDSL Link StatusDSL UptimeDSL modulationANNEX ModeCurrent ProfileSystem Vendor IDSystem Vendor Model IDModem Vendor ID
A2pvfbH043k.d26r
Link up
0 days 0 hours 6 minute(s) 56 seconds
ITU G.993.2(VDSL2)
ANNEX B
17a
Infineon:0xb206
41327076666248303433670000000000
Infineon:0xb206
Line StatusTCM(Trellis Coded Modulation)SNRLine AttenuationPath ModeInterleave DepthData RateMAX RatePOWERCRCHECESSESFECINP
 DownstreamUpstream
ON
ON
6.2 dB6.8 dB
30.8 dBN/A
InterleavedFast
2591
11150 kbps558 kbps
13013 kbps581 kbps
5.2 dbm5.1 dbm
00
00
470
00
11920
3.00 symbols0 symbols
VDSL Band StatusLine Attenuation (dB)Signal Attenuation (dB)SNR Margin (dB)
 U0D1U1D2U2D3U3D4U4
8.0
28.0
70.8
88.6
66.1
8.0
35.0
6.8
6.2
9 REPLIES 9
Message 2 of 10
Re: here we go again...
Apologies in advance for the formatting.
Message 3 of 10
Hi there @Silent_Bobgrid
Just having a look at the DSL checker info you posted, that's a crazy FTTC speed.  Couple of idea's:
Are you in your Main/Master Socket? Anything apart from your router connected to it?  If you have a landline phone, check for any noise on the line (this will instantly affect any speeds).  With a phone (preferably corded) plugged into the main socket (if possible) dial 17070 and select Option 2.
With regards to the socket does it look similar to this
During the daytime, it maybe a good idea to access the "Test Socket" as shown and connect just router and filter to it, and see what speeds you get.  Bit let us know 1st what your setup is.
Hope this helps.
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
Message 4 of 10
Good evening, Im using the master socket and it has a filter in the faceplate, nothing else is attached. Ive replaced all the cables.  I get the same using test jack, tried that this morning.  17070 quiet line test has a slight buzz on it but whether that slight buzz is acceptable or not is a different matter...
Message 5 of 10
@Silent_Bobgrid
thanks for that info, is the phone corded or cordless? Was it plugged into the test on it's own? Cordless phones sometimes "buzz", a corded phone shouldn't.
If it's corded, and it buzzes without the filter, I would suggest reporting it as a VOICE fault, and confirm you have used the "test socket". Do not mention Broadband when reporting the fault.
Kind Regards
CJT80
Message 6 of 10
Its an analogue butt phone. I work on pbx's so this isn't beyond me, ill try reporting a line fault tomorrow and see what they say.
Amazing thing is that dsl checker says fttp but they wont let me have it haha
Thanks for your input.
Message 7 of 10
@Silent_Bobgrid
Does it look like this:
Note where it say's "on demand".
Just curious.
Kind Regards
CJT80
Message 8 of 10
It doesn't say FTTP it says FTTP on Demand. This is a different product and only a few suppliers offer it. It is primarily a business product and I believe that BT has stopped offering it.
Message 9 of 10
Exactly like that!
Message 10 of 10
Gotcha 😊
