Hi for the past 10 months i have been downloading at 35.5mb...my max data was 43.000 min 38.000 but about a week ago my download speed dropped to 31mb and i noticed the noise on my line had jumped up to9.9db my hh5 keeps re booting every 1 or 2 days here are todays stats..does this mean the lower my max data rate goes..the lower my download speed will be ? is there any chance my stats will go back up ?
5. DSL uptime: | 0 days, 20:03:27 |
6. Data rate: | 7405 / 33478 |
7. Maximum data rate: | 9062 / 38391 |
8. Noise margin: | 5.9 / 8.3 |
9. Line attenuation: | 38.3 / 23.7 |
10. Signal attenuation: | 26.9 / 21.3 |
your attainable will fluctuate during the day as your line condition changes - mine does.
your connection speed will improve when you can get a stable connection 24/7 for a few weeks and DLM reduces your noise margin back to about 6db which will increase your connection speed - but need stable connection
hi imjolly...as my noise margin is lowering..so is my max speed..by the time it gets to 6db my max speed may be around 34.000 so my download speed might drop even more ?
your noise margin will also fluctuate on a daily basis probably recovering in the morning and then fluctuating during the day - again mine does in fact it is fluctuating more in last couple of days than it has done in last 6 months
so in your opinion is there a chance my max data rate mite go back up to 43 and my download speed may go back up to 35mb ? i just carnt see it going back up myself...my download speed has dropped by 4 mb so far..and my noise margin is still 8.3 surely by the time it drops to 6db my down load speed maybe under 30mb ?
if your noise margin gets reset to 6db by DLM after a few weeks of stable connection then I would expect an increase in you connection speed not a decrease. an increase in your data rate will increase your profile and therefore your download speed
Hi today my stats have changed..my noise margin has gone up again to 9.7 and my max data rate has also gone back up..but..my download speed is still only 31mb instead of 35mb...my max data going back up..is it a good or bad thing ?
data rate 33478...max data 42670
as I posted already your attainable rate and noise margin will fluctuate during a day depending on weather which changes line conditions. that does not change your actual data rate or profile
so basically the only way my speed is going to go back up..is if my line stays stable for over a week and my noise margin comes down ? well at the moment my hh5 re boots every 36 hours...im wondering if it has something to do with bt upgrading some people to 52mb..maybe im paying the price in speed reduction for there upgrade
