chris889
Message 1 of 4
homehub 5
just want to know if their is anything on here that needs improving or is fine
. Product Name: HomeHub5 2.     3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 17/12/2015 4. Board version: 01 5. VDSL uptime: 5 days, 21:12:05 6. Data Rate: 7958 / 72283 7. Maximum Data Rate: 13536 / 86930 8. Noise Margin: 14.8 / 6.3 9. Line Attenuation: 23.9 / 15.1 10. Signal Attenuation: 0.0 / 0.0 11. Data sent/received: 3.5 GB / 126.8 GB 12. Broadband username: bthomehub@btbroadband.co
3 REPLIES 3
imjolly
Message 2 of 4
Re: homehub 5
your connection looks stable with 5 days conenction time.  I would hope for a higher up speed nearer attainable and similar with down speed.  you don't have to do anything apart from remain connected 24/7 and DLM will eventaully make any changes necessary
http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
chris889
Message 3 of 4
Re: homehub 5
yea it has been up for 5 days but usually discconects on the 10th day
imjolly
Message 4 of 4
Re: homehub 5
just leave it connected and a reset every 10 days will not affect it - mine used to reset every 14 ays like clockwork but speed and noise margin were the same when it re-connected immediately
