just want to know if their is anything on here that needs improving or is fine
. Product Name: HomeHub5 2. 3. Firmware version: v0.07.05.0A13-BT (Type B) Last updated 17/12/2015 4. Board version: 01 5. VDSL uptime: 5 days, 21:12:05 6. Data Rate: 7958 / 72283 7. Maximum Data Rate: 13536 / 86930 8. Noise Margin: 14.8 / 6.3 9. Line Attenuation: 23.9 / 15.1 10. Signal Attenuation: 0.0 / 0.0 11. Data sent/received: 3.5 GB / 126.8 GB 12. Broadband username: bthomehub@btbroadband.co
Solved! Go to Solution.
your connection looks stable with 5 days conenction time. I would hope for a higher up speed nearer attainable and similar with down speed. you don't have to do anything apart from remain connected 24/7 and DLM will eventaully make any changes necessary
http://community.plus.net/library/browsing/fttc-dlm-what-it-is-how-it-works/
yea it has been up for 5 days but usually discconects on the 10th day
just leave it connected and a reset every 10 days will not affect it - mine used to reset every 14 ays like clockwork but speed and noise margin were the same when it re-connected immediately
