Message 1 of 6
hot spots
Being an established Gmail user, I have set my Btinternet.com Email up as client based, If and when I get a laptop/tablet,  will I be able to log into BT Hot Spots or do I need to setup a BT web mail.?
5 REPLIES 5
Message 2 of 6
Re: hot spots
Just use your BT Broadband primary e-mail address and password.
Message 3 of 6
Re: hot spots
   I was wrongly assuming I would use the email setting password to go with my email username, but on checking my broadband settings, that also has my email as the username, so as I would be connecting to BT broadband I should use broadband setting password, please confirm.
Having set my BT email up as client based on my home PC. and that email account not being on the proposed laptop, is irrevelant?
Message 4 of 6
Re: hot spots
if connecting to hotspot/btwifi then you need to use your primary btinternet.com address and password.
not sure what you mean about your hub username should bthomehub@btbroadband.com and any password
Guru
Guru
Message 5 of 6
Re: hot spots
Hi wayfayer,
To login to a BTWifi (previously called BTFon/BTOpenzone) hot-spot, all you need to do is connect to the SSID and on the landing page enter your Primary BT Account email and password.
Landing page looks a bit like this:
For your emails you can either use the BT Yahoo Webmail interface here: http://mail.yahoo.com or you can use an email client such as Microsoft Outlook, Thunderbird, ect...
To use IMAP settings:
Incoming:
servername : imap.mail.yahoo.com
port: 993
Security: SSL/TLS
Outgoing:
servername: smtp.yahoo.com
port: 465
security: SSL/TLS
To use pop3:
Incoming:
servername (POP3)  : mail.btinternet.com
port: 110
Outgoing:
servername (SMTP)  : mail.btinternet.com
port: 25
For both mail client methods you use your BT Yahoo mail account username and password.
Hope that helps,
Cheers
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Distinguished Guru
Distinguished Guru
Message 6 of 6
Re: hot spots
I think you're reading too much into this.
The only relevance of BT's webmail to BT Wi-Fi hotspots is that the log-in details are the same. Whether you use an email client, webmail, or nothing at all has absolutely nothing to do with it. When you're in range of a hotspot you can simply connect to it as described by jac.
