1. Product name: | BT Home Hub |
2. Serial number: | +068343+NQ34526626 |
3. Firmware version: | Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 03/07/15 |
4. Board version: | BT Hub 5A |
5. DSL uptime: | 0 days, 00:02:46 |
6. Data rate: | 3381 / 12784 |
7. Maximum data rate: | 3380 / 13102 |
8. Noise margin: | 6.1 / 6.2 |
9. Line attenuation: | 32.7 / 24.8 |
10. Signal attenuation: | 32.8 / 20.3 |
11. Data sent/received: | 0.9 MB / 20.8 MB |
12. Broadband username: | bthomehub@btbroadband.com |
13. BT Wi-fi: | Yes |
14. 2.4 GHz Wireless network/SSID: | BTHub5-ZQZJ |
15. 2.4 GHz Wireless connections: | Enabled (802.11 b/g/n (up to 144 Mb/s)) |
16. 2.4 GHz Wireless security: | WPA2 |
17. 2.4 GHz Wireless channel: | Automatic (Smart Wireless) |
18. 5 GHz Wireless network/SSID: | BTHub5-ZQZJ |
19. 5 GHz Wireless connections: | Enabled (802.11 a/n/ac (up to 1300 Mb/s)) |
20. 5 GHz Wireless security: | WPA2 |
21. 5 GHz Wireless channel: | Automatic (Smart Wireless) |
22. Firewall: | Default |
23. MAC Address: | 18:62:2c:4a:3d:2a |
24. Modulation: | G.993.2 Annex B |
25. Software variant: | AA |
26. Boot loader: | 1.0.0 |
im using the same front cover that i had in my old house which gave me 76mb connection which is attached to the only socket in the house
on the outside of the house is a connection box , im going to check that out
i have on several occasions in previous house re-routed my telephone cables and installed new master sockets, i mean its 1 orange and 1 white wire so its not exactly difficult.
is the outside box like this
if you conenct to test socket then check that your extension sockets do not have a dial tone
the outside box is a black cylindical tube for connecting 2 lenghs of telephone cable, the 2 wires from each end a paired together in clear plastic sealed connectors, they looked fine.
ok
what about the check for dial tone with extension sockets?
i dont have any other sockets
is it possible to conenct to the test socket with a filter and repost the hub stats. if speed just the same then you need to phone customer services and get engineer visit as conenction speed below estimate
i dont use a filter, havnt in years, just straight into master socket dsl terminal
as i mentioned this socket i actually brought from my old house and it is wired up exactly as it was in previous house where i got 76mb on infinity 2
up to you - then you need to get engineer visit
Following on from this thread
https://community.bt.com/t5/BT-Infinity-Speed-Connection/house-move-issues/m-p/1646014
it has now been 6 weeks since we moved.
The problem i am having is, i just cannot get through to bt to speak to someone
i have lost count of the amount of calls i have made, the first time i got through via ringback i was told to wait 10 days for a line upgrade to 55mb, so i waited and nothing changed, the udgrade should of happened by the 26th july. and as i said it didnt happen,
so i started ringing up and eventually i had 2 ringbacks within 10mins of each other, both to tell me the systems were down and to try again in 4 hrs, which i did but no body rang back, so i tried to wait on the line, 1.5 hrs later i gave up and tried ringback, only for no one to bother.
this has been happening every day i try to get through.
i have have tried the complaints line only to suffer the same.
i have been with bt many years and when the service is working its great but whenever there was a problem i always dreaded having to call.
luckily for the past 4 yrs i hant had to call other than to make this house move. but wow i have not ever known bt to be so bad as these last 6 weeks.
on top of all this i am still being billed for option 2 which i had in my old house, despite only supposedly being on option 1
i am only writing this as i simply cannot seem to get through, no matter what time of day i call
please help
