Message 11 of 23
Re: house move issues
1. Product name:BT Home Hub
2. Serial number:+068343+NQ34526626
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 03/07/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:02:46
6. Data rate:3381 / 12784
7. Maximum data rate:3380 / 13102
8. Noise margin:6.1 / 6.2
9. Line attenuation:32.7 / 24.8
10. Signal attenuation:32.8 / 20.3
11. Data sent/received:0.9 MB / 20.8 MB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-ZQZJ
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-ZQZJ
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:62:2c:4a:3d:2a
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
im using the same front cover that i had in my old house which gave me 76mb connection which is attached to the only socket in the house
Message 12 of 23
on the outside of the house is a connection box , im going to check that out
i have on several occasions in previous house re-routed my telephone cables and installed new master sockets, i mean its 1 orange and 1 white wire so its not exactly difficult.
Message 13 of 23
if you conenct to test socket then check that your extension sockets do not have a dial tone
Message 14 of 23
the outside box is a black cylindical tube for connecting 2 lenghs of telephone cable, the 2 wires from each end a paired together in clear plastic sealed connectors, they looked fine.
Message 15 of 23
ok
what about the check for dial tone with extension sockets?
Message 16 of 23
i dont have any other sockets
Message 17 of 23
is it possible to conenct to the test socket with a filter and repost the hub stats.  if speed just the same then you need to phone customer services and get engineer visit as conenction speed below estimate
Message 18 of 23
i dont use a filter, havnt in years, just straight into master socket dsl terminal
as i mentioned this socket i actually brought from my old house and it is wired up exactly as it was in previous house where i got 76mb on infinity 2
Message 19 of 23
up to you  - then you need to get engineer visit
Message 20 of 23
Customer services
Following on from this thread
https://community.bt.com/t5/BT-Infinity-Speed-Connection/house-move-issues/m-p/1646014
it has now been 6 weeks since we moved.
The problem i am having is, i just cannot get through to bt to speak to someone
i have lost count of the amount of calls i have made, the first time i got through via ringback i was told to wait 10 days for a line upgrade to 55mb, so i waited and nothing changed, the udgrade should of happened by the 26th july. and as i said it didnt happen,
so i started ringing up and eventually i had 2 ringbacks within 10mins  of each other, both to tell me the systems were down and to try again in 4 hrs, which i did but no body rang back, so i tried to wait on the line, 1.5 hrs later i gave up and tried ringback, only for no one to bother.
this has been happening every day i try to get through.
i have have tried the complaints line only to suffer the same.
i have been with bt many years and when the service is working its great but whenever there was a problem i always dreaded having to call.
luckily for the past 4 yrs i hant had to call other than to make this house move. but wow i have not ever known bt to be so bad as these last 6 weeks.
on top of all this i am still being billed for option 2 which i had in my old house, despite only supposedly being on option 1
i am only writing this as i simply cannot seem to get through, no matter what time  of day i call
please helpWoman Sad
