kd84afc
Message 1 of 4
how do i contact a moderator?
I need help with a Openreach issue
3 REPLIES 3
Message 2 of 4
Re: how do i contact a moderator?
what is your openreach problem ? The community members may be able to help you with out the moderators help
kd84afc
Message 3 of 4
I need to found if I got a openreach records issue causing me problem when i try  to order BT infinity... as most of street can order BT infinity and I cannot.. Both houses next to me left and right are able to order it so I want to rule any other issue before i go back to BT..
Message 4 of 4
This is a link to the mods
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3 working days
They are a UK based BT specialist team who have a good record at getting problems solved
