Message 1 of 3
how do i find my external IP address?
I have a homehub 3.
1. How do I find my HomeHub3 router's external IP address?
2. Is this external IP a static address?
3. If I plug a second router in, going from the GigE port of my BTHomeHub3 to the WAN port on my 2nd TP-Link router will I need to change the external IP address on the TP-Link router?
I'm trying to set up a second network of the BT Homehub. So that anything done on the BT Homehub3 wont affect me on the second network I want to set up with the TP-Link router.
I plugged in the TP-Link router TL WR841N from the WAN to the GigE port on the homehub3,  then plugged my laptop into the GigE port on the TP-Link and it had an internet connection, the internal IP address of the router was different to the homehub3, and then checked on the computer to see if I could see the other computer on the homehub network and it couldn't; so it seems to work.
I just want to make sure it's all set up correctly.
Can anyone help me with what I need to check to make sure it's all set up correctly?
2 REPLIES 2
Message 2 of 3
Re: how do i find my external IP address?
@richie40 wrote:
I have a homehub 3.
Just type whats my ip in Google
No
No it will get an address from the HH
AS long as you don't want to do any port forwarding you should be ok.
Message 3 of 3
Thanks for the quick and helpful response 🙂
