hi folks
how do i read and understand the event log to try to find this on going fault, when I speak to the Engineers they don't appear to know what the event log is saying
here is the on going story
been having BB drop out probelms for years, since I rejoined BT, at least the engineers come out and try to find the faults
around the start of the year engineer came to my home and we took out all the phone cables other than 1 direct from master to my home phone
start of november different engineer came out and replaced the phone cable from my house to the connection box where my cable and 2 of my neighbours connect to a main cable, for 3 weeks my interndet was great, I never saw it drop out, but then it starting dropping out and over last few days its been almost unusable
I reported it again, and hopefully an engineer will came out before christmas,
before they replace the phone line from my house to the connection, I could almost ay when it was going to fail as I felt it was wind/rain related (if it was windy or quite wet it would fail suggesting it was damaged cables) , but since the phone line was replaced and it restarted failing I can't but a reason to the failure
being an intermittant fault, its hard to trace,
if fault was in the house you could work out what circumstace's brought the fault up, (ie someone walking up stairs, or walking across a room or electrical equipment switched on etc)
the only thing i can think of is putting monitoring equipment on the line, so it splits the line exchange to connection box-monitoring equipment- to phone line to house
at least then you know which side the fault is on
I have posted speedtests before, what i'm trying to find out is if anyone can tell how to read & understand the logs
I have an on going probeim that has been going on for years, the engineers come out and do a bit of work, and the fault stops for a few weeks or months but then it returns
If i can understand the logs I may beable to get the engineers to put a data logger on my line so they can track the fault and sort out the probelm,
in the past i could put the fault down to windy/rainy conditions, but since the phone line from house to first connection box has been replaced I can't tie the BB drop outs to weather conditions, or to movements or things being swith on/off in my home
thanks for any help
17:27:27, 20 Dec. | (115184.500000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
17:27:27, 20 Dec. | (115184.500000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
17:27:17, 20 Dec. | (115174.210000) PPP IPCP Receive Configuration ACK |
17:27:17, 20 Dec. | (115173.970000) PPP IPCP Send Configuration Request |
17:27:17, 20 Dec. | (115173.960000) PPP IPCP Receive Configuration NAK |
17:27:15, 20 Dec. | (115171.690000) PPP IPCP Send Configuration ACK |
17:27:15, 20 Dec. | (115171.690000) PPP IPCP Receive Configuration Request |
17:27:14, 20 Dec. | (115171.000000) PPP IPCP Send Configuration Request |
17:27:14, 20 Dec. | (115171.000000) WAN operating mode is DSL |
17:27:14, 20 Dec. | (115171.000000) Last WAN operating mode was DSL |
17:27:12, 20 Dec. | (115169.470000) PPPoA is up - VPI: 0, VCI:38 |
17:27:12, 20 Dec. | (115169.450000) CHAP authentication successful |
17:27:09, 20 Dec. | (115166.360000) CHAP Receive Challenge |
17:27:09, 20 Dec. | (115166.350000) Starting CHAP authentication with peer |
17:27:09, 20 Dec. | (115166.350000) PPP LCP Receive Configuration ACK |
17:27:09, 20 Dec. | (115166.330000) PPP LCP Send Configuration Request |
17:27:09, 20 Dec. | (115166.330000) PPP LCP Receive Configuration Reject |
17:27:09, 20 Dec. | (115166.330000) PPP LCP Send Configuration ACK |
17:27:09, 20 Dec. | (115166.330000) PPP LCP Receive Configuration Request |
17:27:09, 20 Dec. | (115166.170000) PPP LCP Send Configuration Request |
17:27:06, 20 Dec. | (115163.160000) PPP LCP Send Configuration Request |
17:27:03, 20 Dec. | (115160.160000) PPP LCP Send Configuration Request |
17:27:00, 20 Dec. | (115157.160000) PPP LCP Send Configuration Request |
17:26:57, 20 Dec. | (115154.160000) PPP LCP Send Configuration Request |
17:26:54, 20 Dec. | (115151.160000) PPP LCP Send Configuration Request |
17:26:51, 20 Dec. | (115148.160000) PPP LCP Send Configuration Request |
17:26:48, 20 Dec. | (115144.990000) ETHoA is up - VPI: 0, VCI:35 |
17:26:48, 20 Dec. | (115144.980000) DSL is up |
17:26:47, 20 Dec. | (115143.820000) DSL noise margin: 6.10 dB upstream, 13.80 dB downstream |
17:26:46, 20 Dec. | (115143.330000) DSL line rate: 1095 Kbps upstream, 9724 Kbps downstream |
17:26:35, 20 Dec. | (115131.860000) CWMP: session closed due to error: No response |
17:26:35, 20 Dec. | (115131.840000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
17:26:35, 20 Dec. | (115131.830000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
17:26:04, 20 Dec. | (115101.520000) CWMP: session closed due to error: No response |
17:26:03, 20 Dec. | (115099.630000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
17:26:03, 20 Dec. | (115099.630000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
17:26:02, 20 Dec. | (115099.310000) CWMP: Initializing transaction for event code 4 VALUE CHANGE |
17:25:58, 20 Dec. | (115094.990000) DSL is down after 1 minutes uptime |
17:25:58, 20 Dec. | (115094.990000) ETHoA is down after 1 minutes uptime |
17:25:57, 20 Dec. | (115094.590000) PPPoA is down after 1 minutes uptime [Waiting for Underlying Connection (WAN DSL - Up)] |
17:25:53, 20 Dec. | (115090.110000) PPP LCP Send Termination Request [User request] |
17:25:07, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Invalid tcp flags for current tcp state: TCP [192.168.1.70]:53668->[208.43.241.178]:80 on ppp0) |
17:25:00, 20 Dec. | (115036.630000) CWMP: session completed successfully |
17:24:59, 20 Dec. | (115036.370000) CWMP: HTTP authentication success from https://pbthdm.bt.mo |
17:24:55, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:62019->[173.194.65.138]:443 on ppp0) |
17:24:53, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:62068->[31.55.163.207]:443 on ppp0) |
17:24:51, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:62025->[216.58.213.142]:443 on ppp0) |
17:24:49, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:62021->[64.233.187.94]:443 on ppp0) |
17:24:49, 20 Dec. | BLOCKED 5 more packets (because of First packet is Invalid) |
17:24:49, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:62058->[216.58.208.66]:443 on ppp0) |
17:24:49, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:62016->[74.125.136.95]:443 on ppp0) |
17:24:49, 20 Dec. | OUT: BLOCK [65] First packet is Invalid (Packet not in tcp window: TCP [192.168.1.67]:62027->[216.58.213.174]:443 on ppp0) |
17:24:49, 20 Dec. | (115025.750000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username |
17:24:49, 20 Dec. | (115025.740000) CWMP: Session start now. Event code(s): '4 VALUE CHANGE' |
17:24:39, 20 Dec. | (115015.740000) PPP IPCP Receive Configuration ACK |
17:24:38, 20 Dec. | (115015.510000) PPP IPCP Send Configuration Request |
17:24:38, 20 Dec. | (115015.510000) PPP IPCP Receive Configuration NAK |
17:24:37, 20 Dec. | (115014.300000) PPP IPCP Send Configuration ACK |
17:24:37, 20 Dec. | (115014.300000) PPP IPCP Receive Configuration Request |
17:24:36, 20 Dec. | (115013.540000) PPP IPCP Send Configuration Request |
