Davidwalker600
Message 1 of 5
how do you set up dns
i need to set up a dns sever for a sound server but i do not know how to config it on the bt homehub
4 REPLIES 4
Message 2 of 5
Re: how do you set up dns
As far as I know you cant change the DNS in the home hub.
Davidwalker600
Message 3 of 5
for a shoutcast server port forwarding
quails
Message 4 of 5
You'll need to ditch the HH and buy a router that actually has some configurability to it - BT have taken the view that any feature not used or understood by a large number of customers is to be removed as it may increase support costs.
I bought an Asus wl-500w new from ebay for around £30, to get maximum features I put dd-wrt open firmware on it, but just to enable dns you don't need to go that far. I changed to setup OpenDNS on my router and to enable me to lock down my daughters PC to 2Mbps (nasty Daddy - but Skype was using all our download allowance).
Hopefully BT will see the light at some point and allow basic router configurability on the HH3.
dcullum
Message 5 of 5
You cant do it on the home hub, but their is nothing to stop you setting one or more DNS servers manually on your PC (or Mac)
