Rosin_Ddu
Message 1 of 5
how to get changed onto fast path instead of interleaving
hello i what to get onto fast path because my line is stable enough to support it but my latency is a bit slow for gaming so how do i get on fast path
4 REPLIES 4
Message 2 of 5
Re: how to get changed onto fast path instead of interleaving
Hi I suggest you contact the forum mods they should be able to get that sorted for you this is a link to them
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone within 72 hours
Message 3 of 5
Hi again I have just looked at another post of yours
this link
http://community.bt.com/t5/BB-Speed-Connection-Issues/Bad-broadband-speed/td-p/266353/page/3 from your hub stats you are already on fast path
Rosin_Ddu
Message 4 of 5
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:35:45
Downstream4,384 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)6.2 dB / 22.0 dB
Line attenuation (Down/Up)45.0 dB / 25.0 dB
Output power (Down/Up)19.1 dBm / 11.9 dBm
Loss of Framing (Local)0
Loss of Signal (Local)0
Loss of Power (Local)0
FEC Errors (Down/Up)981533 / 0
CRC Errors (Down/Up)393 / N/A
HEC Errors (Down/Up)N/A / 0
Error Seconds (Local)105
Message 5 of 5
Ok i was looking at you post of 9.39 this morning as you appear to to have had a disconnection due to your now low connection time i would suggest at this time you remain on interleaving as changing to fast may only resort to interleaving going back on automatically again within a few days to stabilise your line
however that choice has got to be yours
