dfenceman
Expert
Message 1 of 11
http://speedtest.btwholesale.com/ on a Sky line
Hi,
Should http://speedtest.btwholesale.com/ work on a Sky line ?
I keep getting :-
The Performance Tester is currently unable to run a speed test for your broadband connection. Please try again shortly, however if this problem persists, raise the issue with your service provider.
Best regards,
dfenceman
10 REPLIES 10
Guru
Guru
Message 2 of 11
Re: http://speedtest.btwholesale.com/ on a Sky line
Hi dfenceman,
The BTWholesale speedtester will not fully function on the Sky LLU services however it will fully function on Sky's BTWholesale service (ie Sky Connect).
Hope that helps
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
Message 3 of 11
It does not function on any LLU line also the Wholesale availability checker will not function on a phone number check as the as the lines are no longer Wholesale Property
dfenceman
Expert
Message 4 of 11
Hi jac95 & john46,
Many thanks for your replies.
The exchange is Yaxley = http://www.samknows.com/broadband/exchange/EMYXLEY) but the line only has Sky connect which I don't think is LLU ?
Best regards,
dfenceman
Message 5 of 11
The exchange shows sky as providing LLU it sounds like that line is connected to their network not the BT network do they pay line rental to sky ?
dfenceman
Expert
Message 6 of 11
Hi john46,
Yes, they do pay Sky for line rental.
I have tried finding a Sky speedtester with no success
Best regards,
dfenceman
Message 7 of 11
they do not have one to my knowledge
dfenceman
Expert
Message 8 of 11
Hi john46,
Thanks again.  That's probably why I can't find it thenSmiley LOL.
I was just trying to check my son's speed as I am stuck here and there is nothing more interesting on TV than Wales - v- Argentina.
The BT one completed the first test but not the further diagnostics.
His speed is worse than mine at 1.8Mbps and that in the city of Peterborough on a development built only 3 years ago.
Interesting to note that Cambridgeshire CC have been insisting that all new developments hace to be fibre connected in order to get planning permission.
Best regards,
dfenceman
dfenceman
Expert
Message 9 of 11
Hi guys,
The further diagnostics is not working on my line at home this morning, so maybe it is a problem with the tester ?
Is anyone else having the same problem ?
Best regards,
dfenceman
Message 10 of 11
just ran diagnostic test and worked ok
