iain_sherriff
Message 1 of 55
hub 2 throttling ?
I am in  slooooooooooooow area Smiley Indifferent
but normally things are OK.
There is one time that I get problems.when I try to download a backup of my web space. Not all of it, just a forum. The download is around 900mb. Using Filezilla or Cute I get the same problem with both.
If I download small parts with a rest in between I'm OK.
My ISP can see no problems.
So
Ii start the download and soon get connection timeouts. At this time I CAN connect everything else, just not my own webspace.....BUT I can connect to everything using my mobile or anything else that doesnt go through my HomeHub.
It is as if the Hub has decided not to let any more traffic from my web space?
Is this possible and can I stop it happening
54 REPLIES 54
Message 2 of 55
Re: hub 2 throttling ?
are you connected to the HH2 wired or wireless?  I presume BT are your ISP if using hub
iain_sherriff
Message 3 of 55
wired to hub.
I meant Host not ISP, sorry.
Message 4 of 55
Post your hub stats so we can see your connection rate etc.
Message 5 of 55
it could be p2p throttling on upload as a thought
iain_sherriff
Message 6 of 55
hub stats from the desktop programme ?
would p2p throtling be BT or host ?
thanks for helping
Guru
Message 7 of 55
P2P throttling would be caused by B.T
If you want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side If the the reply answers your question then please mark as ’Mark as Accepted Solution
Message 8 of 55
Hi Welcome to the forums
Here are some help pages done by CL Keith http://www.btinternet.com/~cbeddoe/speed/Speed.html
also post your full hub stats details shown in this link http://www.btinternet.com/~cbeddoe/others/adslstats.html
Can you also post the full results fromBT Speedtest speedtester.bt.com
Have you tried connecting to the test socket at the rear of the master socket    Test Socket.jpg
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
This is a customer to customer self help forum the only BT presence here are the forum moderators
iain_sherriff
Message 9 of 55
thanks for the detailed reply.
maybe i added a red herring by sayign I am in a slow area.................it has always been slow here (long way from exchange etc) but i have always been able to do what I need until the last few weeks.
on a string of 12 hr night shifts at the mo but I will get those results soon as .
Message 10 of 55
Ok post back when you can we can then help you further
