Message 11 of 55
Re: hub 2 throttling ?
I hope this is what's needed 🙂
Download speedachieved during the test was - 2.55 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.87 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 3 Mbps
ADSL line status
Connection information
Line stateConnected
Connection time0 days, 0:10:44
Downstream3,936 Kbps
Upstream448 Kbps
ADSL settings
VPI/VCI0/38
TypePPPoA
ModulationITU-T G.992.1
Latency typeInterleaved
Noise margin (Down/Up)5.3 dB / 20.0 dB
Line attenuation (Down/Up)38.0 dB / 22.0 dB
Output power (Down/Up)19.1 dBm / 12.3 dBm
Message 12 of 55
your stats look ok with your profile consistent with your conenction speed
with your attenuation I would however expect a bit faster conenction speed nearer 7mb
are you connected to the test socket or master socket?  do you have other sockets in your home apart from the master whether in use or not?
Message 13 of 55
not on master.
dont recognise the "test socket" as something in my box.
there are other sockets.
still on nights........... will check those sunday pm.
I can still surf normally and use interactive sites and watch iplayer etc and they seem same as always have been and can download other files/images. It's just getting locked out of my space when FTP'ing that is an issue.
eg at the moment my wife is using betfair and listening to sportinglife radio while I am posting and all is OK.
Message 14 of 55
tes socket is behind the bottom half of the master if master NTE5 type
as you have other sockets have you removed the orange bellwire from terminal 3 in all your sockets as this is a known cause of noise on your line
bellwire removal
Message 15 of 55
my sockets are just plastic box with wires and a face plate with socket. Both the same.
I will get onto BT I think and get some new up to date sockets put in.
Thinking about this some more my problem isn't connection dropping...........I still have net connection just no connection to my server. Also when the connection drops it is instant.This is part of the error message from Cute
STATUS:> [29/04/2012 14:36:15] Transferring file "/forum/Themes/default/fonts/President/u.gif"...
COMMAND:> [29/04/2012 14:36:15] PASV [29/04/2012 14:36:15] 227 Entering Passive Mode (213,175,206,64,103,213)
COMMAND:> [29/04/2012 14:36:15] RETR u.gifSTATUS:> [29/04/2012 14:36:15]
Connecting FTP data socket... 213.175.206.64:26581...
ERROR:> [29/04/2012 14:36:36] The connection failed due to an error or timeout. .
STATUS:> [29/04/2012 14:36:36] Waiting 30 seconds...ERROR:> [29/04/2012 14:36:37] Control connection closed.
To me that is saying that an error (rather then a delay) causes the problem. It onlt tires to connect once more but the control connection is closed.
I'm sure I may increase my speed following your suggestions but I dont know if the slow speed is the actual cause ??
Message 16 of 55
...ignore the smilies !
Message 17 of 55
if you get BT to replace the sockets it will cost at leat £130 as there is nothing wrong with existing sockets
does the socket where the BT wires enter your home feed the other socket so one is master and other the slave?
Message 18 of 55
the overhead cable comes to the hose to a box on the wall outside. There are two sockets inside and each have a cable coming from the outside box. How the actual connection is I dont know!
So newer sockets wouldn't make much difference ?
Message 19 of 55
Message 20 of 55
you can check to make sure that the bellwire was not connected to terminal 3 - if it was you should remove it.  normal connection is to terminals 2 & 5
