Message 41 of 55
Re: hub 2 throttling ?
since then I have moved the router to the master socekt (and so doen away with the extenssion lead) and have yet another improvment 🙂
Message 42 of 55
that's great - must notice a big difference  - well worth the effortSmiley Wink
Message 43 of 55
looking good could you please post a new set of hubstats just for reference
Message 44 of 55
moving my stuff around as well, backup drives and printer going direct off router and doing away with old PC upstairs
will do monday. weekend of nights Man Frustrated then  post new stats. Profile should have settled by then
Message 45 of 55
please keep us posted on how you get on
Message 46 of 55
Smiley Frustrated
so I have this problem back again...........
My profile is now at 6.5
actual acheived is 5.91 down and .45 up.
BIG improvement after your advice.
but I'm still getting the timeout problem when FTP'ing ?
quick recap....... i can download small files a few at a time (using filezilla but others are the same).
If I try to download my full webspace (25mb) part way through it stops saying timeout error.
At this point I can connect to anything else from the same laptop (wireless or ethernet make no difference) APART from my webspace or anything on it (email etc).......but I can connect to the space from my mobile or from anything that does not go through my home hub.
If I reboot the home hub i can connect again, but the next day I have to go through it all again.
BT are convinced they have nothing wrong and so are my ISP
bit stuck now................................
Message 47 of 55
just had a thought!
i will put stuff on my BT webspace (if I have any, never tried) and see if I get the same thing
Message 48 of 55
worth a try
Message 49 of 55
My host suggested ttying WS_ftp Pro with some specific settings...............made no difference.
I have some space with HostPapa that I had forgotten about!!
so I have just tried with FileZilla and WS_ftp uploading and downloading a coupkle of times the same folder that fails with my host
and have had no problem Smiley Surprised
is there anything that could be happening (permisions or something) with my homehub or BT account with one specific domian but not with others ?
Message 50 of 55
"BT are convinced they have nothing wrong and so are my ISP"
Who is your isp
