ITtech
Message 11 of 18
Re: hub keeps disconnecting + slow downstream its beyond a joke ..
One of 2 things has happened here, you've either reset the router multiple times in fairly quick succession in an attempt to get a better speed, and what's more you did it at night, which is not good ... and the noise margin has risen from target to 16db, but as yet, the BRAS server has not been updated from the rate adaption module at the dslam (rambo), and the IP is still up there. But unfortunately within the hour it will update, and the IP will plummet. OR ..... you have suddenly got a line fault, that is causing loss of signal, and high error rates, and has caused DLM to reduce the throughput and raise INP accordingly.
Click the star if my posts have helped.
razten
Message 12 of 18
trying to do the speedtest on the old hub and it wont let me (confused)
null
You appear to be logged in as bthomehub@btbroadband.com. In order to run the next test you must login as speedtest@speedtest_domain.
Please wait while you are redirected..
waited for almost 10 minutes..
and this is the adls details on the old hub
DSL Connection
Link Information
Uptime:0 days, 0:12:26
Modulation:G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:798 / 2,575
Data Transferred (Sent/Received) [MB/MB]:1.32 / 5.48
Output Power (Up/Down) [dBm]:12.5 / 20.0
Line Attenuation (Up/Down) [dB]:21.5 / 44.0
SN Margin (Up/Down) [dB]:2.0 / 13.5
Vendor ID (Local/Remote):TMMB / TSTC
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):36 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):56 / 0
FEC Errors (Up/Down):2,155,970 / 85,343
CRC Errors (Up/Down):126,766 / 2,009
HEC Errors (Up/Down):372,192 / 1,465
Line Profile:Fast
Message 13 of 18
hi your connection speed is considerably faster the errors are concerning though it is noticeable that this hub is showing fast and the other hub interleaved some of those errors would change if this was interleaved there have been a number of disconnections was this due to you setting this hub up or was it restarting on its own
razten
Message 14 of 18
the hub is restarting on its own
altough it didnt restart in the last couple of hours im not sure if it will stop forever
oh and my phone line is really bad its hissing and making crackling noises so i think its all due to my phone line and not the hub
ITtech
Message 15 of 18
Then you need to report a bad line, the bb will look after itself.
razten
Message 16 of 18
great... hub is resetting again.
hamish72
Recognised Expert
Message 17 of 18
You have done all you can its down to BT now Smiley Surprised
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Message 18 of 18
when you phone bt to report your line noise do not mention broadband as when the line is sorted your broadband will improve soon after
