Shelly
Newbie
Message 1 of 3
hub phone 2.1 and bt infinity nub 2.0
hi i have recently got a hub phone 2.1 and i have bt infinity with a 2.0 hub , i cannot get the phone to register to the hub. ? any one help !!
the btbroabband account is not yet acivated but i was hoping to just use the hub phone for the land line calls only, i have the phone lead connected correctly and tried reseting the hub and still no luck registering the hub phone.
Any ideas
Tags (2)
2 REPLIES 2
Message 2 of 3
Re: hub phone 2.1 and bt infinity nub 2.0
Hello Shelly,
Broadband Talk (BBTalk) has been deprecated by BT. They no longer support it or supply it to new or upgrading customers.
However, you may or may not be able to get it to work, as there are some people using BBTalk with Infinity on Infinity HH2.0s. They (and the instructions for getting it working) are here:
http://community.bt.com/t5/BT-Infinity/BT-Infinity-amp-Broadband-Talk/td-p/56396/page/2
Hope this helps and good luck,
Message 3 of 3
Another helpful post for doing the actual registration:
http://community.bt.com/t5/BT-Infinity/BT-Infinity-and-No-Hub-Phone/td-p/19241/page/2
Using the above instructions, you should (hopefully) be able to get the Hub phone/s to work as just a normal landline with the Infinity Hub 2.0. They may or may not work for BBTalk depending on how your account got switched.
