Message 1 of 3
iPad e-mail
Hi there
I can receive e-mail but not send any, I have deleted my account and reset it up, and I have checked that the settings are the same as quoted on your website as:
Host Name: mail.btinternet.com
User Name: my user name
Password:   my password
Use SSL is checked
Authentication is password
Server Port is 465
Please help this is the third time that this has happened to me and deleting and resetting up has not helped this time.
2 REPLIES 2
Message 2 of 3
Re: iPad e-mail
If you can, you are best to set up the email on the tablet manually rather than using a wizard.
When setting it up you need to decide if you want to use IMAP or POP. Once you have decided use the settings in this link. Make sure that you enter your username and password in both the incoming and outgoing servers. If it is offered, don't use the option "use same as incoming". You may have to enter your full email address ie. xxxx@btinternet.com in the username, not just the prefix ie xxxx before the @btinternet.com.
http://bt.custhelp.com/app/answers/detail/a_id/44917/kw/bt%20mail/c/346,6588,6591
See link for settng up email guide.
http://bt.custhelp.com/app/answers/detail/a_id/46673/~/setting-up-your-bt-email-account-on-a-mobile-...
Settings:
POP3
Server incoming and out going: mail.btinternet.com
Email user name: (Normally you only need the prefix of your email address but some users have found the need to enter their full email address.ie xxxxx@btinternet.com)
Password: Your BT email password.
Log on using clear text authentication
Out Going Server in requires Authentication (Use same as incoming mail server. Some users have found that they need to enter the password and username instead of ticking box “use same as incoming mail server” )
Outgoing Port : 465 SSL security
Incoming Port : 995 SSL security
IMAP
Same as above except for Incoming Port: 993 SSL security
Expert
Message 3 of 3
Re: iPad e-mail
if you go settinngs>mailcontacts>select the mail account>account>outgoing mail server>do you see a primary and other smtp servers? are any "on"
