william347
Message 1 of 6
iPad is connected at 5MHZ but HH5 shows connection is 2.4MHZ
My HH5 wireless is set up with different SSID and passwords for 2.4 MHZ and 5MHZ.
My iPad connects at 5MHZ automatically when switched on and is accessing the internet successfully.
It cannot connect to 2.4MHZ without asking for the password.
The HH5 Device List shows the iPad connected at 2.4MHZ.
Can any one explain why and how to correct ?
5 REPLIES 5
imjolly
Message 2 of 6
Re: iPad is connected at 5MHZ but HH5 shows connection is 2.4MHZ
why don't you make password same for both SSID?
stevebrass
Expert
Message 3 of 6
Under settings - wifi select the 2.4 ssid and select forget it.
Switch wifi off then on and then log on again to the 2.4 ssid. Make sure you select auto join and auto log in.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
william347
Message 4 of 6
Tried a restart and everything back to normal. iMac and iPads don't like the same ssid for both 2.4 and 5MHZ.
Thanks for assistance.
licquorice
Message 5 of 6
You can have the same password for different SSIDs
delboy-lee
Message 6 of 6
Fortunately I have not experienced any problems with my iPad or iPhone wifi connections from HH5
and my 2.4 & 5.0 MHz ssid are set as follows:
Wifi ssid For  HH5
2.4 MHz  - BTHub5-6RN9
5.0 MHz. - BTHub-6RN95
Notice the 5.0 MHz has a 5 at the end of the character list
Us same Password for both ssid
