JMGP
Message 1 of 9
ibminiupnpc
Just wondered if any one can help please. I have noticed that the above has appeared on the port forwarding section of the new BT Smart hub I have. It seems to only apply to my daughters ipad. I cannot delete it in the advanced / port forwarding section of the hub. I'd like to know what it is please and why I can delete it, as I did not install it. Thanks
Tags (1)
8 REPLIES 8
Keith_Beddoe
Message 2 of 9
Re: ibminiupnpc
You need to disable uPnP on the home hub to prevent automatic mapping of external ports.
smf22
Recognised Expert
Message 3 of 9
Re: ibminiupnpc
Something on your daughters iPad is using Universal Plug and Play (UPnP) to signal to the router to add port forwarding for these ports.
You could try disabling UPnP under Advanced Settings -> Firewall -> Configuration and changing the UPnP botton to 'Off'.
Regards
JMGP
Message 4 of 9
Re: ibminiupnpc
Many thanks for your help. I have disabled UPnP but I still cant delete it from the list of port forwarding that has been set up. I'd like to be able to delete this as opposed to just disable UPnP. Is that possible? What is strange is both the X to delete and the tick to confrm are visable next to the 'rule' but neither work.
Keith_Beddoe
Message 5 of 9
Re: ibminiupnpc
First you will have to reset the home hub to factory default. Then before anything connects to the home hub disable uPnP.
The home hub has a habit of remembering old connections, and the only solution is a factory reset which resets the configuration file.
smf22
Recognised Expert
Message 6 of 9
Re: ibminiupnpc
Do you get the same behaviour i.e., can't delete the entry, when the UPnP button is 'On' of 'Off'? Try both and see if you can delete then.
If it allows you to delete the entry with UPnP turned on, remember to turn it off again after.
Regards
JMGP
Message 7 of 9
Re: ibminiupnpc
Correct on or off I can't delete.
JMGP
Message 8 of 9
Re: ibminiupnpc
Firstly many thanks for all your collective help. Problem solved with a reset of the hub, after turning uPnP off, and when it turns on the 'non created port rule' was deleted - and I can now turn uPnP back on. Thanks again all.  JP
Keith_Beddoe
Message 9 of 9
Re: ibminiupnpc
If you have turned uPnP on again, the port will be created again once the app that created it is run, so you will be back to square one.
There should not be a need to enable uPnP, as any port mapping is best done manually. That way you have full control over what you allow to connect to your private network.
