Distinguished Expert
Message 11 of 14
Re: infinity 2 - Question about speed
Wireless is your own problem, 802.11n is much faster then b.
There isn't a bottleneck in BT's network, it's probably more an issue with speedtest.net servers being throttled. Try some other locations and www.speedtest.bbmax.co.uk
vertuas
Newbie
Message 12 of 14
Thanks for the suggestion.  Here are some result for other servers :
milton keynes   39.12 / 11.88
london, namesco  41.36 / 6.34
 london, virtual internet  42.14 / 15.69
conventry, warwicknet 42.16 / 16.02
Whilst slightly better these are still not even close to the BT results.
I got 22.15 / 15.83 with speedtest mini on out webserve, based by Memset in Reading.
vertuas
Newbie
Message 13 of 14
Wireless is only a problem when I'm not on a wired connection, with wireless turned off.  I previously posted about the wifi issue after BT tech support and 2 vists from Openreach engineers could not fugure out why our speed was limited to a maximum of 23 meg!
You would think that Openreach engineers would could across that issue often!!!! I finally fingered out that issue myself!
Thanks for the other speed test i get 52268k / 14429k, so thats an improvement!
Goooner
Message 14 of 14
I've had strange results from Speedtest.net ever since I had Infinity installed about 10 days ago.
The BT checker says I'm getting aroung 85-95mb down (FTTP) and about 8-10mb up (up seems low, but not really bothered about that) but speedtest, apart from the very first day, has only ever given me 25-40mb down and 8-11 down, whichever server I use.
I've posted the BT results here and the consensus is that my stats and IP profile all look as the should.
