alancamuk
Message 1 of 26
infinity 2 gone slow and unstable again
it's been pretty stable for a couple of months now, at 77mb, down and 20mb up...
last few days video streaming and downloads seem slowed so ran the bt wholesale speed test.. wow, down to 22mb down and 15 up.. router stats look ok. so asked a neighbour.. they have gone slow also, but have got nowhere with BT's appalling indian call centre, they told them they will just have to accept the slow speed Why BT persist with these imcompetents is beyond me...
here's router stats..
Connection status
 Connection status:
Connected
 Downstream:
80.00 Mbps
 Upstream:
20.00 Mbps
Connection information
 Connection time:
9 Days, 0 Hours 21 Mins 59 Secs
oduct name:
BT Hub 6A
Serial number:
+084319+NQ62835891
Firmware version:
SG4B10002244
Firmware updated:
22-Dec-2016
Board version:
1.0
Gui version:
1.32.0
DSL uptime:
9 Days, 0 Hours 25 Minutes 17 Seconds
Data rate:
20.00 kbps / 80.00 kbps
Maximum data rate:
32814 / 87209
Noise margin:
15.3 / 8.2
Line attenuation:
4.6
Results Image not loaded
1. Best Effort Test:
Download Speed : 23.57 Mbps
2. Upstream Test:
Upload Speed : 15.06 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
25 REPLIES 25
Keith_Beddoe
Message 2 of 26
Re: infinity 2 gone slow and unstable again
Please can you please provide BT Wholesale speed test results for different times of the day, including the further diagnostics page? The last test needs to be done at peak times so the results are stored on the BT server.
These must be done using a computer connected to the home hub, using an Ethernet cable.
It could be just network congestion, but its also worth seeing if your line is noisy, as that will cause errors and re-transmissions.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
gg30340
Message 3 of 26
It sounds like a congestion problem. Have you tried the speed test at different times of the day. Try one in the morning and another in the evening during "peak" times.
Use this speed tester then scroll down the page and carry out the further diagnostics and post back a screen shot of all the results including your IP profile for up and down. This test must be done with a wired connection.
http://speedtest.btwholesale.com/
After you have done the "peak" time one, do not do any more speed tests because the last one will be recorded.
Get your neighbour to do the same. He doesn't need to post the results. It is just to get the results recorded.
alancamuk
Message 4 of 26
latest is getting worse......
FAQ
1. Best Effort Test: -provides background information.
 Download Speed
 15.22 Mbps
0 Mbps77.35 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 15.22 Mbps
 For your connection, the acceptable range of speedsis 40 Mbps-77.35 Mbps .
 Additional Information:
 IP Profile for your line is - 77.35 Mbps
2. Upstream Test: -provides background information.
 Upload Speed
 15.01 Mbps
0 Mbps20 Mbps
Upload speed achieved during the test was - 15.01Mbps
 Upstream Rate IP profile on your line is - 20 Mbps
Webby
Message 5 of 26
Wired or wireless?
alancamuk
Message 6 of 26
that last one was cat 6  wired, currently stuck at 18mb. a few people in the village are saying they've been stuck at 18 - 25mb 24/7 since a power cut (9 days ago) as my uptime shows..
BT are blaming individual pc's tablets etc... which is typical..
pippincp
Message 7 of 26
Which exchange?
alancamuk
Message 8 of 26
hackleton northamptonshire
the fibre cab is in piddington nothants, it's at the end of my garden..
pippincp
Message 9 of 26
I thought it may have been an Openreach cabinet problem following the powercut but there's nothing listed. The problem must be elsewhere.
The mods may be able to assist.
RogerB
Guru
Message 10 of 26
I'm thinking BTo ought to be looking at the power supplies in that MSAN.
