zebie31
Message 1 of 4
infinity 2 slower speeds than sky fibre max, please help
hi, i have infinity 2 for 14 days now, i was with sky fibre max getting a sync speed of around 53mb download. on infinity 2 my sync speed is coming in at around 45 mb. i see my max data rate is 54mb (its always changing, which i think is normal) but the sync speed is 45mb. i have had a steady line no drops i did restart the router to see if the sync speed would improve but it didnt, in the 2 weeks i have only restarted the router twice.also if i was give a estimate of 48 -63 mb why is the acceptable range 40mb to 44.39mb and a ip profile of 44.39mb. all my stats are below and was wondering if someone could help me figure out whats up with the connection, am i being capped or something, thanks
Product name:
BT Hub 6A
Serial number:
Firmware version:
SG4B1000B316
Firmware updated:
01-Oct-2017
Board version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 1 Hours 9 Minutes 52 Seconds
Data rate:
14.95 Mbps / 45.86 Mbps
Maximum data rate:
15025 / 54057
Noise margin:
6.1 dB / 6.3 dB
Line attenuation:
19.1 dB
Signal attenuation:
VPI / VCI:
0/38
Modulation:
G_993_2_ANNEX_B
Latency type:
Fast Path
Data sent / received:
11 MB Uploaded / 108 MB Downloaded
Broadband username:
bthomehub@btbroadband.com
BT Wi-fi:
Not active
2.4 GHz wireless network name:
Toast2ghz
2.4 GHz wireless channel:
Smart (Channel 1)
5 GHz wireless network name:
Toast5ghz-5
5 GHz wireless channel:
Smart (Channel 36)
Wireless security:
WPA2 (Recommended)
Wireless mode:
Mode 1
Firewall:
On
MAC address:
Software variant:
Boot loader:
7.33.1
3 REPLIES 3
imjolly
Message 2 of 4
Re: infinity 2 slower speeds than sky fibre max, please help
with a max speed of 54mb I would first go back to BT and drop to infinity 1 as you cannot get more than infinity 1 max  now Bt are changing infinity 1 to 80mb then you will same money  the increase in speed is free to infinity 1 users
zebie31
Message 3 of 4
when are they changing infinity 1 to 80 mb ? i got infinity 2 as i was given a estimate of 48 - 63 mb download, i did enquire about downgrading but it would require a new 24 month contract and im currently on a 12 month one. do you see anything wrong about my stats that could causing my sync speed to be 45mb
imjolly
Message 4 of 4
as both sky and Bt use the same openreach connection then the only change was the DD payee everything else apart fron router should be same
https://community.bt.com/t5/BT-Infinity-Speed-Connection/Speed-jump/td-p/1780180
