gallaghm
Message 1 of 3
infinity homehub5 keeps needing to be reset
Everything I seem to go online after a few days of non use the speeds drop to less than 10 but after a homehub reset it gets back above 50. No luck with support line, anyone else seen this?
2 REPLIES 2
Moderator
Moderator
Message 2 of 3
Re: infinity homehub5 keeps needing to be reset
Hi gallaghm,
That's not good when you notice the drop in speed is your computer connected wirelessly or wired?  If it's wireless it could be a problem with the wireless channel and resetting the hub is changing this for you. Check out this link and let me know if this helps.
Neil
gallaghm
Message 3 of 3
thanks spoke to BT chat and they also sugested same thing. Have manually set the channel and am using a WIFI analyser app that they suggested to make sure the channel is clear. amd experiencing the problem less now, so hopefully that is the fix.
