Mitosis
Message 1 of 5
infinity speeds
Hey! my partner and i are both using a wired connection straight to the router, we are sat next to each other but when we do a speed test, she has 76mb speed and i see 3mb speed.
Any ideas why it shows a difference in speeds?
4 REPLIES 4
ryant704
Guru
Message 2 of 5
Re: infinity speeds
Could be a broken cable, port or just the computer doesn't have enough processing power. Have you installed your latest Ethernet drivers?
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
Mitosis
Message 3 of 5
Re: infinity speeds
I am gunna change the ethernet cable to the new one i got.
How would i check my drivers i would assume they are upto date.
Thanks for the swift response btw 😄
Mitosis
Message 4 of 5
Re: infinity speeds
changing cable worked, tyvm sir 🙂 ❤️
ryant704
Guru
Message 5 of 5
Re: infinity speeds
No problem, glad to of helped.
