stuart_c
Message 1 of 13
infinity2 slow down
Hi
My connection has slowed down, for some reason my hub rebboted the other day and connected at a slower speed. I have taken screen shot from event log to show the difference. How can I get my speed back? Because the speed is within the recognised limits "there is nothing wrong".
10:59:23, 06 Jul.
(571562.540000) PPPoE is up -​ Down Rate=53081000Kbps, Up Rate=13850000Kbps; SNR Margin Down=6.4dB, Up=5.9dB
20:15:19, 29 Jun.
( 138.730000) PPPoE is up -​ Down Rate=67703000Kbps, Up Rate=14108000Kbps; SNR Margin Down=6.4dB, Up=5.9dB
20:01:10, 29 Jun.
( 140.180000) PPPoE is up -​ Down Rate=67531000Kbps, Up Rate=14036000Kbps; SNR Margin Down=6.5dB, Up=5.8dB
As you can see it changed in the 6th July
Has anyone any ideas as to what happened.
I must admit I have been in touch with BT and should have got a call back  yesterday but not holding my breath. I have also attatched an image from my Sam Knows log.
Regards
Stuart
12 REPLIES 12
imjolly
Message 2 of 13
Re: infinity2 slow down
if you have a HH5 can you go to hub manager then trobleshooting then helpdesk and post 1-12
can you run btspeedtester and when first test completes then run diagnostic test and post results  must be done with wired connection  btspeedtester
 are you using test socket with new filter
can you enter your phone number and post results  remember to delete number wholesale FTTC check
try quiet line test   dial 17070 option 2  should be quiet and best with corded phone
stuart_c
Message 3 of 13
Here is the log
1. Product name:BT Home Hub
2. Serial number:+068543+NQ41920610
3. Firmware version:Software version 4.7.5.1.83.8.204.1.11 (Type A) Last updated 07/07/15
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 23:17:44
6. Data rate:13775 / 56567
7. Maximum data rate:13768 / 56445
8. Noise margin:5.9 / 6.4
9. Line attenuation:23.4 / 16.8
10. Signal attenuation:23.4 / 16.6
11. Data sent/received:804.9 MB / 7.2 GB
12. Broadband username:
bthomehub@btbroadband.com
Webby
Message 4 of 13
Can you provide the results for your line from http://www.dslchecker.bt.com please.
stuart_c
Message 5 of 13
I am connected with a filtered face plate.
THese are the results but every time I do the test the results are very different but none show a connection speed anything like I used to get.
Line test is silent
imjolly
Message 6 of 13
Webby
Message 7 of 13
Ensure no other devices are in use.
Please post the data from the Wholesale DSL checker.
stuart_c
Message 8 of 13
DSL checker
Webby
Message 9 of 13
Thanks for that. Your connection speed is a little low.
Can you confirm where your router is connected? Is it in the master socket or an extension?
Do you have a test socket as indicated in the image above from imjolly?
stuart_c
Message 10 of 13
It is connected to the master socket which is an ADSL nation filtered faceplate. I have just removed this faceplate and connected straight into the test socket with a filter, and this is the result.
5. DSL uptime:0 days, 00:06:35
6. Data rate:13865 / 56974
7. Maximum data rate:13887 / 57020
10. Signal attenuation:23.5 / 16.6
11. Data sent/received:0.3 MB / 0.6 MB
12. Broadband username:bthomehub@btbroadband.com
It is as thought I am connected as Infinity1 instead of 2. I was getting these kind of speeds before I upgraded.
If you look at the chart from SanKnows from the last six months you can see when I upgraded and when the speed dropped.
