skelf23
Message 1 of 7
infinity2 upgrade but no change in speed.
Hi all,
 On the 6th of this month I was upgraded from infinity 1 to infinty 2 and was told my speed should increase to at least 48mb from the 37mb on Infinity1. The connection seems to drop occasionally too.
I have HH5 connected to the only connection plate in the house (one on left) Changing microfilters makes no difference. bt-master-socket-size-450px.jpg
Here is the stats from my Hub:
1. Product Name: HomeHub5
2. Serial number: +076284+1435012935
3. Firmware version: v0.07.06.09028-BT (Type B) Last updated 30/10/2016
4. Board version: 01
5. VDSL uptime: 0 days, 05:00:33
6. Data Rate: 7616 / 40148
7. Maximum Data Rate: 7616 / 46112
8. Noise Margin: 6.0 / 4.8
9. Line Attenuation: 21.9 / 22.6
10. Signal Attenuation: 0.0 / 0.0
11. Data sent/received: 59.1 MB / 535.7 MB
12. Broadband username: bthomehub@btbroadband.com
BT Broadband Availability checker :
Any help would be much appreciated, Thanks 🙂
6 REPLIES 6
Webby
Message 2 of 7
Re: infinity2 upgrade but no change in speed.
You need an engineer visit.
skelf23
Message 3 of 7
Thanks Webby, do you think i need an engineer visit because of the faceplate or is it something to do with the attenuation?
Thanks, Ian.
Webby
Message 4 of 7
You have no function to test into the test socket and you're getting below the minimum expected speed.
skelf23
Message 5 of 7
OK Cheers
TimCurtis
Recognised Expert
Message 6 of 7
I doubt there was any point being upgraded to Infinity 2 at extra cost to you when BT only advise speeds of 48mbs.
Recontracting for a year on Infinity 1 should get your connection reset to 55/10 which is more than your line is probably capable of.
Webby
Message 7 of 7
The line has the potential of 70meg, so if the OP wants/needs more speed then it is worthwhile.
Also, some of the recontract deals for Infinity 2 are the same price as Infinity 1.
