so if you use the test socket and do quiet line test - dial 17070 option 2 - do you get crackle with a corded phone?
if drops when phone picked up the possibly a High Resistence fault and need engineer visit by phoning 151 until you can get rid of the line noise you are not going to make any progress with your broadband
Your problem appears tobe that you are reporting a broadband fault where you don't have one. You have a line fault and should report it as that on 151 with no mention of broadband.
Once the line fault is resolved your broadband will (sometimes slowly) recover.
Still no resolution to this fault. I've kept logs of the times the line is noisy along with regular router logs. I've had numerous engineer visits and spent hours on the phone to my case handler (now on the third one). Pho enow so noisy that calls are often impossible, router reports variable speeds but often atttainable rates lower than actual rates, over teh weekend speedtest results were 2mb/s down 1 up on a 76mb/s connection (supposedlly), ping response time varying between 12ms and 300ms.
I'm not sure where to take this now, Ofcom don't deal with individual complaints and as I'm out of contract I'm paying well over £300 per quarter for a service that has now been broken for 10 months. Anyone got any ideas? BT wont consider a refund until the fault is fixed {they've had ample time and I wouldn't be complainng unless there was a fault} or reduce the cost of service unless I sign up for a 12month contract, I wont sign in for 12 months to a broken service.
Anyone have any ideas how I can escalate this? The only thing ~I can think of is going through the small claims court for a refund on a very sub standard service.
PS. for the record: Teh DSLAM has been changed, cabling inside and outside the house to the telephone pole have been chaged. I'm seeing multiple CRCs and FECs plus LOS and LOF failureat both ends, speeds drop untill the connection fails completely and teh router modem resets, they then shoot back up to 70mb/s downsrteam smd the cycle continues.
The phone connection is horrinly noisy although not symetriically. i've been reporting this as a landline phone fault since the beginning of the yesr and have had a number of engineers out, but still no luck. Much of the problem is the massive layer of obfuscation between BT and Openreach, Openreach seem to treat this as a new fault every time and so have no idea of the history.
Any help on how to escalate this would be greatly appreciated
see if forum mods can help you and maybe direct the openreach in the right direction taking into account all the previous engineer visits mods will post help here
