Message 1 of 3
ip profile puzzle
Hi, can anyone make sense of attached stats and advise how to return ip profile to previous of 2.5 instead of the current mind numbing 0.5? or is it a case of wait 3 days and hope?
03:29:18, 09 Mar.
( 183.650000) DSL noise margin: 20.00 dB upstream, 6.10 dB downstream
03:29:18, 09 Mar.
( 183.580000) DSL line rate: 448 Kbps upstream, 3200 Kbps downstream
02:22:16, 09 Mar.
(1137385.190000) DSL noise margin: 25.00 dB upstream, 21.10 dB downstream
02:22:16, 09 Mar.
(1137385.120000) DSL line rate: 288 Kbps upstream, 576 Kbps downstream
23:26:59, 23 Feb.
( 105.140000) DSL noise margin: 21.00 dB upstream, 6.20 dB downstream
23:26:59, 23 Feb.
( 105.070000) DSL line rate: 448 Kbps upstream, 3168 Kbps downstream
9 march
  1. Best Effort Test: -provides background information.
Download  Speed
0.49 Mbps
0 Mbps
0.5 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.49 Mbps
 For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.07 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 0.5 Mbps
10 feb
Download  Speed
2.43 Mbps
0 Mbps
7.15 Mbps
 Download speedachieved during the test was - 2.43 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Your DSL Connection Rate :3.33 Mbps(DOWN-STREAM), 0.32 Mbps(UP-STREAM)
 IP Profile for your line is - 2.5 Mbps
2 REPLIES 2
Message 2 of 3
Re: ip profile puzzle
Indeed, it is but a waiting game.
Message 3 of 3
Thanks for the response, speeds seem to have picked up pretty quickly on this occasion and now back to around the 2.5 mark, so perhaps no need for the patience pills on this occasion
