Message 1 of 3
ipad2 will not connect to wifi network - bt homehub router
I already have connected a MACBook AIR and an MSIWIND network to my home network as well as a wireless printer.  But have not managed to connect my new ipad 2 today.  So back to the Appleshop I will go tomorrow ..will keep you posted...
2 REPLIES 2
Message 2 of 3
Re: ipad2 will not connect to wifi network - bt homehub router
Solved - checked the wireless key on the router and had success connecting, also success connecting ipad2 to a BTfon network.
footsie
Newbie
Message 3 of 3
When you try to connect your iPad2 FOR THE FIRST TIME to your wireless network (Setting>WiFi) . . you are asked for the "PASSWORD"   Now . . when you ordered your BT hub and set it up, you needed a PASSWORD sent to you over the phone by BT. So, naturally you assume that your iPad is waiting for this PASSWORD.  Oooooooh noooooo it isn't!  It wants you to enter the Wireless Key - found on the Hub Settings pull-out tab that came with your hub.
