Message 21 of 33
Re: is correctly connected ?
if you have reset to factory setting then yes the hub would normally conenct straight away right out the box - no changes needed
Message 22 of 33
Sorry that ask simple questions, but does not want to be connected Smiley Frustrated
must be connected automatically ?
without a user name, password and other?
Message 23 of 33
When you recive the hub from BT there are no changes required - just take out of box and connect to master/test socket with a filter and you should be able to get internet conenction assuming line activated. A factory rt using the recessed button on back takes hub back to how it comes out the box
does your phone work if connected to the filter?
Message 24 of 33
Do not use the telephone !
Router which was given by BT does not work (try with another BT Homen hub 2)
Message 25 of 33
same applies all home hubs will connect automatically providing the phone line is active
Message 26 of 33
If you don't have a phone how do you know phone like is working. It also helps check if there is a noise problem in addition your package will probably include free weekend calls
Message 27 of 33
is it possible by ADSL filter directly into laptop ?
Message 28 of 33
If you haven't got a phone, you don't need a filter.
Message 29 of 33
I want from hub, directly into the laptop. Will there be a problem to connect to the Internet
Message 30 of 33
Connect phone socket to dsl port on the hub. Connect lan port on the hub to Ethernet port on the laptop.
