I have a friend who has a static ip address with plusnet, is it possible to do the same with BT?
Solved! Go to Solution.
No, BT Retail do not offer it. BT Business do.
If you use a DDNS service like No-IP, then that works fine in most cases.
Thanks works with no-ip thanks for your help
