jamjar62
Expert
Message 1 of 12
is this right
Hi All  Is it right that your Infinity speed should go up and down by 10Mbps when you do a speedtest ?
JamJar62
11 REPLIES 11
plainview
Recognised Expert
Message 2 of 12
Re: is this right
Your throughput will always vary, nowt you can do about it.
ryant704
Guru
Message 3 of 12
Re: is this right
Shouldn't vary that much over ethernet, maybe 5/6mbps but 10 could indicate a problem somewhere on his line or to the server. You should check on another server as it may have problems or is being overloaded.
If this helped you please click the Star beside my name.
If this answered your question please click "Mark as Accepted Solution" below.
jamjar62
Expert
Message 4 of 12
Re: is this right
Hi there i am on wireless does that make a diference ?
JamJar62
john46
Message 5 of 12
Re: is this right
Hi yes doing speedtests on a wireless connection will never be as reliable as a wired connection due to outside levels of interference can affect speed accuracy
MBR123
Expert
Message 6 of 12
Re: is this right
Yes John is write, I agree, luckly I have a Netgear WN2000RPT on the go, whcih I get the same results wireless as ethernet connection. Everyone slates the repeater but I think its excellent for me, cannot fault it in anyway, a bit expensive though at the time of purchase, wether its the same price now, I dont know, but good buy!. 🙂
Please click on white star to the left and say thanks if I have helped you at all!. 🙂 Thank you. Some handy links Copy & Paste:-
http://bthomehub.home/
http://netalyzr.icsi.berkeley.edu/index.html
http://diagnostics.bt.com/login/?workflow=Speed
ryant704
Guru
Message 7 of 12
Re: is this right
Would never pay for a repeater, easy to make.
Get some sticks and plank of wood. Place it where you want and cover it with tin foil best solution ever!
MBR123
Expert
Message 8 of 12
Re: is this right
Are you saying you can repeat and extend your signal with two planks of wood and cover it with tin foli??? are you having a joke or serious? I have never heard of that way in any of my days. Please tell me I'm intrigued!.
And how can you connect your tin foil repeater up to ethernet???
jamjar62
Expert
Message 9 of 12
Re: is this right
well i have heard of this when i worked in an electronics firm you solder the wires to the tin foil and then plug it into the socket , not sure how good it is lol
JamJar62
ryant704
Guru
Message 10 of 12
Re: is this right
haha, if you take actual time it will be better than a repeater, you shouldn't judge something just because of it's appearence.
