Davidwalker600
Message 1 of 5
itv/bbc player problem
the itv player does stop working on my pc via bt infinty wired connection i do not have the bt version i do not know if it is the same can someone find out if its itv and bbc.
4 REPLIES 4
Moderator-Retired
Message 2 of 5
Re: itv/bbc player problem
Hi Davidwalker600,
Are you still having trouble with this? Have you noticed any trouble with your speeds?
Chris
BT Moderator Team
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Davidwalker600
Message 3 of 5
i notice with speedtest.net when i chack it goes to the top and drops to like 10mb on a 40mb connection but the up speed is not affected
Davidwalker600
Message 4 of 5
bbc iplayer is not a problem now it is only itv player
seab20
Expert
Message 5 of 5
itv player has lost of issues still including loading problems that are no fault of your own
