john46
Message 11 of 27
Re: keep losing signal & poor speed
your connection speed is low for you attenuation however your noise margin is correct and it is hard to see where any improvement in connection speed could be achieved
andy2308
Message 12 of 27
Still doesn't explain why the signal keeps going. When it failed earlier I connected the phone straight to the master socket without a filter and couldn't hear the broadband signal at all.
Only other thing I can think of is that we're suffering due to the Olympics!
andy2308
Message 13 of 27
just lost signal again- green light on Netgear router turned red, rebooted it and it took forever to re-establish again, this is what the home hub kept doing. It's driving me nuts!
Keith_Beddoe
Message 14 of 27
Really need the full home hub ADSL Statistics  including all of the error counters, to really see what is going on.
You will not "hear" the broadband signal, as it uses radio frequencies.
john46
Message 15 of 27
there are NO problem being caused due to the Olympics there is more than enough capacity on the network to cover that event 2 or 3 times before any problems would be seen
andy2308
Message 16 of 27
Well today the Netgear has kicked out 4 or 5 times, sadly it doesn't automatically reconnect when the signal is lost so has to be rebooted each time, a quick internet search reveals that this is a common Netgear problem so it's going back and I've reverted to the homehub.
I'll see how it runs over the next day or so and then post some stats from it but clearly there are still issues with the signal being lost.
Speed is still around 0.62Mb which is woeful compared to what we were getting.
A.
jac_95
Guru
Guru
Message 17 of 27
Hi,
are you able to post your adsl line stats for the home hub:
Go to http://192.168.1.254 or http://bthomehub.home
2) click Settings
3) Click Advanced Settings
4) Click Broadband
5) Click Connection or sometimes called ADSL
The direct Address is http://bthomehub.home/index.cgi?active_page=9116 (for bthomehub3)
Cheers,
jac_95 | BT.com Help Site | BT Service Status
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Try a Search
See if someone in the community had the same problem and how they got it resolved.
john46
Message 18 of 27
the restarts have most likely reduced your IP profile you now need 3 /5 days stable connection for it to rise again
andy2308
Message 19 of 27
Trouble is, it doesn't stay connected long enough to build up any speed!!!
It's just lost signal again:
So I let it sort itself out and reconnect, now it's back up:
andy2308
Message 20 of 27
..but on the plus side, at least it's got faster!
