HMT
Message 1 of 2
last 3 weeks not good broadband speed
hi
last  3 weeks  i  m  getting  very  bad  internet speed
today i   check  from speed tester here is the  result
 Download speedachieved during the test was - 10087 Kbps
 For your connection, the acceptable range of speedsis 4000-21000 Kbps.
 Additional Information:
 Your DSL Connection Rate :16506 Kbps(DOWN-STREAM), 1216 Kbps(UP-STREAM)
 IP Profile for your line is - 14000 Kbps
The throughput of Best Efforts (BE) classes achieved during the test is - 18.54:25.54:55.93 (SBE:NBE:PBE)
These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
any body  tell me  how i can solve my  problme
regards
1 REPLY 1
Message 2 of 2
Re: last 3 weeks not good broadband speed
There is nothing wrong
With your speed your speed test shows a 16 mb connection and a 10 mb download speed the download speed will vary constantly as general internet activity varies and is perfectly normal
