A_mars_reject
Message 1 of 6
leaving BT - do i need to return my equipment?
As above, will I need to return my hub, vision box etc., or can I just bin them?
5 REPLIES 5
Message 2 of 6
Re: leaving BT - do i need to return my equipment?
You bin tech stuff ?
My loft is a Tech Museum.
An MSCE in computing is like having a McDonalds Certification in World Cuisine, pointless.
Guru
Message 3 of 6
Arthur Negus would be proud ....  eh Paul?     Smiley Very Happy
Same with me matey ....  🙂
hamish72
Recognised Expert
Message 4 of 6
Chances are BT wont want it but remember there is  hard drive in the V box (I think )
And it should all be recycled (Under EU regs Smiley Very Happy )
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Distinguished Guru
Message 5 of 6
You should be recycling all old electricals these days.  BT may decide to send you a big post-paid envelope to send the equipment back.  If not, you can just take it to your local waste tip/recycling centre.
robinbredin
Message 6 of 6
I would not dump anything, until you hear from BT.
