Message 11 of 29
Re: limited broad band speed
Thanks, this is odd. Neighbour has cabinet!
Telephone Number 01387xxxxxxx on Exchange DUMFRIES is served by Cabinet 18
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability Date Left in JumperHigh Low High Low        VDSL Range A (Clean)
For VDSL Range A the term "Clean" is a line which is free from any wiring issues (e.g. Bridge Taps) and/or Copper line conditions.VDSL Range B (Impacted)
For VDSL Range B the term "Impacted" is a line which may have wiring issues (e.g. Bridge Taps) and/or Copper line conditions.
69.948.21811.841.8Available----
67.142.217.510.134.8Available----
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33030--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date WBC SOADSL Availability Date Left in JumperWBC ADSL 2+WBC ADSL2+ Annex MADSL MaxWBC Fixed RateFixed Rate
Up to 12--7 to 17AvailableAvailableYes
Up to 12Up to 17 to 17AvailableAvailableYes
Up to 6.5--5.5 to 8AvailableAvailable--
2----AvailableAvailableYes
2----Available----
Observed Speeds VDSLMax Observed Downstream SpeedMax Observed Upstream SpeedObserved Date
66
9.87
2020-04-27
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Premise Environment StatusBridge TapVRINTE FacePlateLast Test Date
N
N
N
01-05-2020
FTTP is not available.
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Jan 2013. the Formal Retirement date for IPstream is from 30 Jun 2014.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
Message 12 of 29
And similar with other neighbour. They have cabinet 18. (And grand speeds)
And I got them up by looking at telephone numbers which I couldn't do for mine....and then I had to get it via address...
What does this now mean. Help?!
Message 13 of 29
That would explain why you cannot get fibre and your neighbours can. Once you get your line connected then try the checker again as that may give a similar result to your neighbours which would then enable you to upgrade to fibre
openreach will not move you to a cabinet just to improve your broadband connection
just need to wait until your new BT connection is up and running
Message 14 of 29
Thanks. That’s very helpful.
so I’ve taken a new contract with BT and the kit will arrive end of May. Is the suggestion that I wait till I get it and then try upgrade to a faster connection? But then I’ve committed  for 2 years at 10 MBPS (guarantee of only 2)  so why would them want to invest in hardware?
How should I work on it now? If only I could speak to BT on phone!
Message 15 of 29
Once you get your BT connection then that will update openreach database  which hopefully will then show you are connected to the same cabinet as your neighbours which in turn will enable you to upgrade to fibre
nothing more you can do until BT connection up and running
Message 16 of 29
Thanks so far. I’ve now set up my BT hub and internet (&TV). Get 11 Mbps. Which I guess is the fastest speed my line can cope with.  So how do I get faster speed and request open reach to help improve connections to home?
Message 17 of 29
If up and running now enter phone number and post results.
Message 18 of 29
Telephone Number 01387xxxxxx on Exchange DUMFRIES
Up to 15--11.5 to 18AvailableAvailable--
Up to 15Up to 111.5 to 18AvailableAvailable--
2----AvailableAvailable--
2----Available----
Other Offerings Availability DateADSL Multicast
Available
U
Thank you for your interest
Message 19 of 29
Do these numbers mean anything to the cognoscenti?
Message 20 of 29
the last dslchecker results don't show a cab number so you are conencted direct to exchange and is the reason you cannot get a fibre connection.  before you ask openreach will not move your line just so you can improve your broadband - numerous post on the subject
your speed range is shown as 11.5/18mb.  can you post connection stats from your router
are you using the test socket with a filter to see if that helps with your connection speed
